Help With Thermaltake UX100 on a MOBO w/out ARGB header + installing new RGB fans
Solved by thrasher_565,
1 minute ago, sp4cehum4n said:These are the connections coming from the UX100. I have nowhere to connect the Ground and Data wires on my mobo, so I'm looking for the correct controller that would take those as well as some new fans I have yet to purchase.
oh ok then if you dont have an mb header you can get ether an manual controller or an internal usb controller. list of all the software controllers i could find.
