1 minute ago, direwolf500 said:
I was originally going to go with a 3400G but then I heard about a 4650G, and found that It is compatible with B550. Is it also compatible with B450? I have everything except the CPU and GPU.
So just to confirm: You are NOT getting a discrete video card?
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
They're quite rare and expensive. Did you actually find one at a good price? If not, stick to your original plan of the 3400G
Primary PC:
PSU tier list
How many watts do I need?
2 minutes ago, direwolf500 said:
$290? Amazon?
I didn't even know there were OEM listings for that processor available, thought they were system integrator only.
It's a sizeable improvement in performance so it's not a bad idea to opt for it.
Primary PC:
PSU tier list
I didn't either. Time to go update advice I gave about 10 minutes ago...
https://www.amazon.com/AMD-Ryzen-Processor-3-7Ghz-Threads/dp/B08MWMGRH7
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
