I need to control the fan speed of my Dell laptop (it has one fan, the CPU fan). I have tried a few software like SpeedFan, HWMoniter, ArgusMoniter, but they don't detect the fan. HWInfo detects the fan, but the fan curve I set on it is not followed by my laptop. I can only control it when I click 'set manual' but the change only stays for 2-3 seconds, before the fan goes back to its original speed. I couldn't find any fan control in the BIOS. What should I do?
https://linustechtips.com/topic/1326235-fan-control-software/
Unless there is some miracle thing provided by dell to change it, the bios most likely is locked down to prevent what your attempting to do. That seems like the most reasonable reason why when you try to manually set it it does it for a few seconds but goes back to regular is because the bios is enforcing the factory fan curve. Might not be why but seems like the most likely reason to me.
(You dont say what dell laptop this is so I'm assuming this is some run of the mill dell laptop not a 'gaming branded one'
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1326235-fan-control-software/#findComment-14644416
