Budget (including currency): about 1000€ (excluding GPU)
Country: Greece
Games, programs or workloads that it will be used for: MSFS 2020, DaVinci Resolve, Eclipse
Selected Parts:  CPU:Ryzen 7-3800X (possibly 3700X if I cannot find it) Motherboard:Asrock MB B550 Gaming 4 Phantom Cooler:Cooler Master Liquid Lite 240 MLW-D24M-A20PW-R1 RAM:G. Skill Ripjaws V 16GB DDR4-3600MHz (GSKF43600C19D16GVRB) PSU:Be Quiet System Power 9 600W CM SSD:Western Digital-SN550 Blue M.2 - 500GB Case:Inter-Tech B-02 RGB - Black Monitor: DELL S2721HGF As for the GPU, I reflowed a dead Nvidia GT 9800 and I am going to use it until the gpu prices become reasonable and probably buy a 3060 ti.
Theese parts are about what I want so my questions are:  Is anything not powerful enough? Are they compatible? Is there anything better at about the same cost?
Note:I prefer AMD CPUs and don't like rgb
https://linustechtips.com/topic/1326224-build-advice/
don't bother with the 3800x, just go for the 3700x, the difference between them is minimal.
case is pretty bad, find something with better airflow, that has a mesh front like a focus G or p300a mesh
i would get a better quality psu, especially if you want to upgrade to a better gpu in the future.
if you want to stick to bequiet, go for the pure power series instead. otherwise, a corsair txm is a good option, or a seasonic focus gold.
https://linustechtips.com/topic/1326224-build-advice/#findComment-14644361
