building advice needed
32 minutes ago, notAfanOf said:ps: were the new mb and ram a bad decision?
RAM, no. Mobo, maybe? It doesn't actually do anything for you here, though it puts you in a better state for upgrading other components like CPU later.
As far as things to watch out for, a big one is removing the cooler and CPU from the old board. After you unscrew the cooler, gently rotate it slightly back and forth until you feel it loosen, before pulling it off. If you just yank it up, there's a high likelihood of ripping the CPU out of the socket and potentially damaging the pins.
Also verify the motherboard standoffs in the case and that they match the positioning of the holes in the new mobo. If a stray standoff makes contact with the PCB, you can potentially short. When installing the mobo in the case, use a magnetic screwdriver. Some of the screw placements can be awkward to get at, and losing a screw somewhere under the mobo sucks.
It's best to install everything on the mobo except for the GPU outside of the case. You can use the mobo box as a makeshift test bench, if you don't have a mat or other protected non-conductive surface. This makes it much easier to get at everything. It's also not a bad idea to do a test POST before actually installing it in the case (temporarily install the GPU), just to ensure everything is working.
Mark out the locations of the various power cable connections for the board and components, and run the cables through any cable routing holes before installing the motherboard. This can sometimes be difficult to do after the fact.
