Budget (including currency):  €1000
Country: Netherlands
so i really want to build a pc and i already chose wich parts i would want but i’m not sure if there are good
cpu: ryzen 5 3600
motherboard: asus prime x470-pro
ssd crucial: p2 500gb
hd: seagate barracuda 1tb
psu: corsair cv series 550watt
ram: crucial ballistix 3200MHz 16GB
gpu: 3060ti
case: be quiet pure base 5000DX
note: some thing aren’t available right now like the gpu and mother board so i’l have to wait on those parts bit thats no problem for me
https://linustechtips.com/topic/1326098-pc-parts-help/
cpu: ryzen 5 3600
gpu: 3060ti
Don't go for x470, get a good B550 board, or if you wanna save even more, a good B450 board, even a B450 board will support Ryzen 5000 series if you decide to upgrade later with a simple BIOS update, you'll be getting PCIE Gen 4 with B550, aka future proofing.
Quote
The primary difference between B450 and B550 is the increased PCIe general purpose lanes that also benefit from becoming PCIe Gen3, rather than PCIe Gen2. - Gamer's Nexus
Change the SSD to SN550, it's better at a similar price. Change the PSU, to CX from CV.
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1326098-pc-parts-help/#findComment-14643576
