Cable Connector
Go to solution Solved by Oshino Shinobu,
You can just fold it back and zip tie it. Wouldn't advise cutting it off as you'd render it useless if you ever got a card that needs an 8 pin connector.
7 minutes ago, truvisk said:
So i have a 6+2 Connecter for my gpu, and i dont need the extra 2. can i cut it off or can i do something else?
No don't cut it off. It could potentially be dangerous.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
https://linustechtips.com/topic/1325832-cable-connector/#findComment-14641661
