39 minutes ago, Difficult Problems said:
@stewzzz Cpu? Ram? and all the other specs you have?
  • CPU
    i7 4770k 4.2 ghz oc
  • Motherboard
    Asus z87 Sabertooth ATX LGA 1150
  • RAM
    Corsair Vengeance LP 16BG - 16000mhz ddr3 (8gb x2)
  • GPU
    MSI Gaming X 1080 ti
  • Case
    Cougar MX 330-X ATX Case
  • Storage
    Western Digital 1tb ssd (games)
    Samsung 8600 Evo 500gb ssd (os and other files)
  • PSU
    Gigabyte superb 720w 80+ PSU
  • Display(s)
    Asus VG279 144hz monitor
  • Cooling
    Cooler Master Hyper N520 CPU Cooler
  • Keyboard
    Razer Huntsman mini w/ hyper x pudding keycaps
  • Mouse
    Razer Viper Ultimate Wireless
  • Sound
    Logitech G635
  • Operating System
    Windows 10 pro fully licensed
https://linustechtips.com/topic/1325302-warzone-low-fps/#findComment-14637726
Any difference when you change to High settings?
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1325302-warzone-low-fps/#findComment-14637742
Having FPS issues as well and can’t figure out why basic spec of what I have are
cpu I-5 9600k
HyperX 16b ram
Geforce etc 3070
BenQ 144hz monitor
max in game on low settings I barely get 50 to 60 FPS
all drivers upto date
I’m pretty confused
https://linustechtips.com/topic/1325302-warzone-low-fps/#findComment-14641831
cpu I-5 9600k
HyperX 16b ram
Geforce etc 3070
BenQ 144hz monitor
I’m pretty confused
id be so pissed thats a decent set up even better than mine and im getting more fps than you.
im pretty sure its the nvidia drivers and the game...
wait till they have dlss and you should be fine
https://linustechtips.com/topic/1325302-warzone-low-fps/#findComment-14659934
Well today i had my first customer who complained about this. Looked a bit throughout the net and it turns out in like 95% of the cases this happens on systems with nVidia GPU and below 10th gen intel CPU. There were few suggestions of changing the game priority in task manager, so i tried it and in that case it helped me (was High, set it to normal and the FPS returned to normal ~110FPS on 9700k and 1080 non-Ti @ 1080p High settings). As a comparison i tried on my system and it gets ~100FPS @ 1080p and everything at high w/o messing with anything (ryzen 3600X and GTX 1070).
So yeah, go ahead and try with different priority setting from task manager and see if it will work for you. I don't think it's an nVidia driver problem, but game code one. Think it really likes to saturate those threads and cores to max and that's why old Intel CPUs tend to lag behind.
https://linustechtips.com/topic/1325302-warzone-low-fps/#findComment-14660064
