1 minute ago, oscar7601 said:
Why would you care about the recommendation anyway when you clearly know what resolution you are targeting?
Is your monitor plugged into your computer via a VGA cable instead of DisplayPort or HDMI?
because some applications aren't really in a 1920x1080 resolution
my monitor is plugged via VGA cable with a HDMI adapter
https://linustechtips.com/topic/1325167-help/#findComment-14636719
Then your VGA cable is the bottleneck. VGA does not support Full HD (1920x1080). Not sure about its maximum resolution but it's definitely below your target.
You ought to change for a DisplayPort cable or HDMI.
PS : I suppose the "recommended resolution" is just what the HDMI to VGA adapter is pretending its resolution is (what it tells the computer to output by default). It does not "tell" your PC to output 1080p by default because it would be useless. Just like telling the computer to output 4K only to have the signal downscaled (this might not be the appropriate word for the process) to a very low resolution would be pretty useless.
https://linustechtips.com/topic/1325167-help/#findComment-14636726
thanks for your input sir have a good day
https://linustechtips.com/topic/1325167-help/#findComment-14636747
