Hi there, I am wondering if anyone can help me on a setup I have started.
I have a bothie, let's call it a shed, in the garden.
It is too far away for any WiFi extenders so I bought a power-line adapter which has been working perfectly.
I would like to be able to have WiFi on my other devices like the phone, which can't use ethernet.
Now my problem is, since I don't get service to use data on my phone, I was trying to find a way to get my phone and consoles to have WiFi.
I have seen many extenders with only outputs, meaning my phone still couldn't connect.
If anyone has any ideas or suggestions I'd be open to try them out, thanks
https://linustechtips.com/topic/1325030-garden-wifi-setup-help/
Just get a cheap wifi router / access point and hook it up to the powerline adaper in the shed.
https://linustechtips.com/topic/1325030-garden-wifi-setup-help/#findComment-14635856
Get ASUS routers for your house and set up Ai Mesh so you only have 1 wifi network to connect to.
-Samuel Valencia
https://linustechtips.com/topic/1325030-garden-wifi-setup-help/#findComment-14635900
