Budget (including currency): $1k (US Dollar)
Country: United states
Games, programs or workloads that it will be used for: possible streaming purposes/ video programming
The total of this without the graphics card is around $640. For the graphics card, I'm picking either the 1660 super, 2060, 3060, or the 5700. I know its a big range but I kinda need to consider options since graphics cards aren't in stock. If anyone has tips on getting one I'm open to hear. The fans are just basic ones from amazon, nothing special or rgb. The case i'm going to get has some fans included as well. This is my first build and I put a lot of research into this but I would definitely be happy to hear any concerns, tips, or recommendations from the community.
https://linustechtips.com/topic/1325022-help-with-my-first-pc-build/
Is the RAM dual channel? If it is you look good to go
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
