You can't perform such math-like operation between a list and a regular string, what you want is to use the remove method from list
print(fruits.remove("apple"))
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
15 minutes ago, GreaseySleezy said:
<fruits = ["apple", "banana", "cherry"]
x, y, z = fruits
print(fruits - "apple")>
Just read the error message. TypeError: unsupported operand type(s) for -: 'list' and 'str'
Meaning: you can't subtract a string from a list.
But you can remove it if you want:
x, y, z = fruits
print(fruits) #output is this: ["apple", "banana", "cherry"]
print(fruits) #output is this:  ["banana", "cherry"]
ಠ_ಠ
8 minutes ago, shadow_ray said:
This won't work. The remove function doesn't return any value. It will just print None.
Oops, my bad, always forget which methods return a new item and which ones modify in place :old-tongue:
Lenovo N23 Yoga
