Budget (including currency):
     - $1200 (preferred, can go a bit over if needed)
Country:
     - United States of America
Games, programs or workloads that it will be used for:
     Gaming in general at 1080p, some video editing,
     I don't have any existing parts
     I have a keyboard and mouse (just need to buy a monitor which is why I have a $1200)
     upgrading from a laptop
     I'm going to buy this summer (hopefully prices for gpus will go down by then)
     1080p 240 fps for csgo and other fps games, 1080p 100+ fps for most other games (like destiny 2, horizon zero dawn, etc.)
     planning on getting the AW2521HF (maybe with a second monitor later down the line)
     upgrading because I'm tired of the fps I get in games on this laptop
PC Part Picker List:
Notes:
This is my first time building a PC. Any and all feedback is much obliged. I am assuming that I'll be getting a GPU somewhere near a price of $450.
https://linustechtips.com/topic/1324488-first-pc-build/
If you don’t have any existing parts, an 11400 is better because it has integrated graphics. Also changed the power supply to be better and storage to be faster, and added a wifi card since the motherboard I chose didn’t have wifi.
PCPartPicker Part List: https://pcpartpicker.com/list/pWYZ3Z
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor  ($183.99 @ Amazon)
Motherboard: ASRock B560 Steel Legend ATX LGA1200 Motherboard  ($129.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($104.99 @ Newegg)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($104.69 @ Amazon)
Video Card: NVIDIA GeForce RTX 3060 Ti 8 GB Founders Edition Video Card  ($450.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Corsair CXM 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($89.99 @ Amazon)
Wireless Network Adapter: TP-Link Archer T4E PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ Amazon)
Total: $1188.63
Generated by PCPartPicker 2021-04-09 17:40 EDT-0400
https://linustechtips.com/topic/1324488-first-pc-build/#findComment-14632589
PCPartPicker Part List: https://pcpartpicker.com/list/hHvGz7
Motherboard: ASRock B560M-HDV Micro ATX LGA1200 Motherboard  ($128.11 @ Amazon)
Total: $1186.75
Generated by PCPartPicker 2021-04-09 17:36 EDT-0400
Agree on everything except the motherboard, spend 1 dollar extra for the b560 steel legend
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1324488-first-pc-build/#findComment-14632595
Total: $1188.63
Thanks for the reply! I just had a few questions.
1) Would I need a cpu with integrated graphics if I’m planning on getting the 3060 Ti?
2) I know it doesn’t cost much but would I need a WiFi adapter if I’m planning on using Ethernet only?
Other than these two questions I had I think the other changes as helpful. Thanks for your reply!
https://linustechtips.com/topic/1324488-first-pc-build/#findComment-14635726
1)Technically no, but in reality yes. If you had the 3060ti in hand today you would not need a cpu with integrated graphics, but since they are all out of stock, you need to use integrated graphics until they come in stock
2)There is no need if you are just using ethernet, the only reason I included it was because the motherboard you choose earlier had wifi
https://linustechtips.com/topic/1324488-first-pc-build/#findComment-14635757
I was only planning  on buying the parts if I was able to buy the GPU. I didn’t know that the motherboard I chose had wifi. Thanks for the info!
https://linustechtips.com/topic/1324488-first-pc-build/#findComment-14635851
You can still use the computer as a basic computer that will be fast and snappy using chrome + discord + productivity apps, and just wait for the graphics card.
https://linustechtips.com/topic/1324488-first-pc-build/#findComment-14635899
