What are you using it for? What kind of games? What resolution (1080p, 1440p, 4K)? Are you going to be doing any productivity work on it besides gaming? If so, what applications?
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
I play Apex, Warzone, and Destiny 2 mainly; I play on an ultra wide 2K monitor (240 HZ), and in terms of productivity I only run the typical programming applications which never posed a problem on my rtx 2060 laptop...
14 hours ago, curiousmind34 said:
Wouldn't get a 10900k for gaming, instead would get a 5800x.
If you need intel get a 10850k.
I really do not need a particular thing in anything, and the reason I’m opting for the 3090 in the first place is that due to the shortage; the price difference between the 3080 and the 3090 isn’t huge at all.
I greatly appreciate the help!
