Budget (including currency): around $1000-1300 aud
Country: Australia
Games, programs or workloads that it will be used for: Mostly work and some gaming
Other details: Want to run Cs:Go, fortnite, Valorant, Minecraft above 70 fps. Don't know what to get for the graphics card. Would this PC be better than the one attached in the image:
Type Item Price
CPU Intel Core i5-10400F 2.9 GHz 6-Core Processor $209.00 @ Centre Com
CPU Cooler ID-COOLING SE-224-XT Basic 76.16 CFM CPU Cooler $35.00 @ PLE Computers
Motherboard ASRock B460M Pro4 Micro ATX LGA1200 Motherboard $128.78 @ JW Computers
Memory Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory $92.00 @ Umart
Storage Crucial P1 1 TB M.2-2280 NVME Solid State Drive $123.46 @ Amazon Australia
Video Card Sapphire Radeon RX 5500 XT 4 GB PULSE Video Card $333.60 @ Device Deal
Case Thermaltake Versa H18 MicroATX Mini Tower Case $49.00 @ PCCaseGear
Power Supply EVGA GD (2019) 600 W 80+ Gold Certified ATX Power Supply $99.00 @ Skycomp Technology
Case Fan ARCTIC F14 77.3 CFM 140 mm Fan $10.00 @ Skycomp Technology
  Prices include shipping, taxes, rebates, and discounts
  Total $1079.84
Do not mind a complete overhaul of the build. Would also like some recommended prebuilts around the price range (Something that can compete or is better than an iMac).
Thanks
https://linustechtips.com/topic/1324257-first-pc-build-help/
well put it this way that 1650 in the picture is worth 170$ if that. I would hold off on a gpu and get a placeholder card if you build this.
I would also recommend a better PSU (500watts or higher from a reputable company.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1324257-first-pc-build-help/#findComment-14630744
Country: Australia
Type Item Price
  Total $1079.84
Thanks
Power supply should be atleast 550w, and you can drop the  extra thermal paste. Consider getting a CPU with integrated graphics and waiting for GPU prices to fall
https://linustechtips.com/topic/1324257-first-pc-build-help/#findComment-14630753
