As  I start to get ready for the warmer months, looking at still contributing to the greater folding cause I am starting to wonder if their is any point putting my CPU's in the folding loop. Right now I have a 10900X and 10900KF both sitting at about 5GHZ, and they are able to spend about 80% of their day folding, but combined at all 40 cores in the folding mix, I am getting under 1 Million points off of them. The 3090 and 2080's are giving me a tad over 11M. At this point I am just not sure that even having the 1M points per day involved is worth the heat offset from the processors.
Has anyone else just stopped bothering with CPU folding? I feel like it may not be worth the effort and heat.
Intel 10900X and 10850KA. NVIDIA 3090FE and EVGA 3090 K|NGP|N Hydro Copper. 196GB RAM. 2x Corsair AX1200I power supplies, $6K in Corsair Hydro-X Custom cooling all wrapped up in a Phantex Enthoo Elite dedicated to supporting F@H (User ID PEZUI on team LTT! 223518)
https://www.reddit.com/r/pcmasterrace/comments/ofazed/i_might_as_well_at_least_commit_to_this_if_i_am/
https://linustechtips.com/topic/1324110-folding-heat-control/
yep. I only use my CPU's for folding in events. Generally speaking, it's not worth it for the amount of power they draw. When you get into the higher core counts this starts to change, but even with my EPYC 7551 32 core it's barely even worth it.
https://linustechtips.com/topic/1324110-folding-heat-control/#findComment-14630194
I don’t fold on my CPUs, just the GPUs but I do use the CPUs for BOINC as their wattage is almost negligible compared to the GPUs.
For the GPUs I run them at a “titch” just above the minimum power limit which greatly reduces the heat with only a very small ~5-10% reduction in PPD. Likewise, the CPUs can be under-volted/under-clocked/power tables adjusted for a significant decrease in power with a similar much less significant heat output.
You can also use FAHclient commands and CRON (Unix) or the Windoze Command Scheduler to “finish” slots before the hot periods and “unpause” them during not so hot periods which is also useful as the “hot” periods generally align with when electricity rates get more expensive in many regions.
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
https://linustechtips.com/topic/1324110-folding-heat-control/#findComment-14632971
