i need some help trying to find the right parts for my girlfriends brother first build hes 15 so does not have to much money, we have the case and PSU 500w i want to build it around the Core i5 3570K, already having the PSU and case i will get him a hard drive and maybe ram all i need is the motherboard and video card, i want it to stay around 300 to 400 at most thanks for the help.
https://linustechtips.com/topic/13239-need-help-on-parts/
Get a cheap socket 1155 motherboard which will fit in the case you have, get the 3570K if it isn't to expensice.
Is the things you already have included in the 300-400 budget? is it in dollars? If it is included then what did it cost?
Get some cheap ram, max 8GB probably. And for the video card (assuming thaf a 15y old bot plays games) some type of AMD for probably the same price as the processor, perhaps a little cheaper if needed.
https://linustechtips.com/topic/13239-need-help-on-parts/#findComment-142447
If that's the case you could grab an MSI Z77a-g41 or g43 or g45 and a 7870?
What do people think?
https://linustechtips.com/topic/13239-need-help-on-parts/#findComment-142671
