Your card is still ok. Bug is unrelated with the video card.
The card will just get slower with every new games release.
And what card do you plan to purchase?
I see you are aware of the prices, yes go for 3060, should be a decent upgrade.
Meanwhile just enjoy your current gpu. It's better than nothing.
