Budget (including currency):
Country: Building My First PC
Games, programs or workloads that it will be used for:
These are the parts that I already got
cpu- AMD Ryzen 9 5950
motherboard- Asus ROG Crosshair VIII Dark Hero
ram- G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 x2
aio- NZXT Kraken Z73
ssd- Samsung 980 Pro 2 TB M.2 x2
case- Lian Li O11D XL
psu- Asus ROG STRIX G 1000 W 80+ Gold
don't have gpu yet but when I put these parts in pc part picker it tell me that there is a problem with the case and motherboard because there isn't enough USB 3.2 Gen 1, is there any way to make the case and motherboard work?
https://linustechtips.com/topic/1323567-building-my-first-pc/
They will still work together fine, just one case port may not be connected or something
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1323567-building-my-first-pc/#findComment-14626058
5 minutes ago, KingofSins said:
is there anything that could be done to make all the ports work?
Look for a cheap adapter maybe
Big nerd.
https://linustechtips.com/topic/1323567-building-my-first-pc/#findComment-14628192
