First Build
Solved by LienusLateTips,
1 minute ago, eddiemar said:Oh okay.
I really wanna get my hands on an RTX 2060 or 2070 super.
And you said it looks unbalanced. Is it bad performance wise? Or are you speaking money terms?
It's bad performance wise. You have an entry level graphics card with a high end CPU. You spent $110 on high end looking RAM when you could spend $30-40 on the GPU instead, etc.
Honestly if possible I'd try to upgrade straight to a 6700 XT/3060 Ti when you can.
