So I’m working with a ryzen 5 2600x msi x470 gaming plus max force 16gb delta ram currently I don’t have a graphics card plugged in though I wanted to see if it would show signs of life and nothing I’ll be showing screenshots of parts ect for further information the rest is self explanatory
And I’ve showed what it looks like so far
https://linustechtips.com/topic/1320599-no-post/
The system won't boot without a graphics card installed.
On your motherboard there are 4 LEDs above the 24pin motherboard connector. Do any of those light up when you try to turn the system on? It should light up VGA if it's stuck trying to POST without a graphics card.
If nothing at all is happening, double check the power connectors are plugged in properly and the switch on the back of the power supply is turned on.
https://linustechtips.com/topic/1320599-no-post/#findComment-14603391
I know it won’t boot I was just looking for signs of life but as far as I can tell when I turn it on the leds are not lighting up unfortunately
https://linustechtips.com/topic/1320599-no-post/#findComment-14603395
