look at your mobo's manual and see what that postcode means
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
On 3/30/2021 at 2:13 PM, kes2006 said:
It means that it has failed to post no cpu detected
theres your problem then
Just now, kes2006 said:
So 3 cpus are dead
Which CPUs have you tried?
Are those 3x CPUs supported by the motherboard, and are they compatible with said socket / motherboard ?
It could be faulty motherboard (socket) rather than 3x faulty CPUs.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
There are no bent pins and all the cpus worked on that mobo before
maybe its a power issue
(also have you tried using them without any gpus installed)
FF doesn't always mean a dead CPU.
It could also mean a problem with the board itself, MSI boards can show it if there are dead MOSFETs in the VRM circuit. I know that from past experience with those boards, that's what happened with one I had but the CPU itself was fine and still works to this day (MSI 790FX-GD70 and a 1100T CPU).
I checked the OP's profile and noted they have a Gigabyte but could still mean something else because if the CPU isn't working, then it isn't and the board is detecting it regardless of the cause.
I do suggest to try another board, I seriously doubt three CPU's would just die like that. If they did it's still another issue as in something had to kill them and that cause would most likely be the board anyway.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
No it’s an evga bord the gigabyte one is from my main rig
Gotcha but the above still applies.
POST codes are universal and mean the same even if the make itself is different.
Plug in the diagnostic speaker and run bare minimum HW to post the board.
If you get error beeps (more than a single beep) the board is operational and see my sig after you get a beep count. AMI Beep codes is what you'll reference.
If you get no beep at all.... the board is most likely dead, but to test it, just remove the memory and it should have a memory beep count, you can also do that with the video card and the beeps for a missing card should be 1 long and 8 short.
Yeah but where is the headers
1 minute ago, ShrimpBrime said:
It happens. A functioning board will always give at least one beep, and many when there's a detected hardware error.
I’ll try and find a new bord then thanks for the help and btw I wish I had 2 780 ti’s lmao
While you look, you can try a long bios clear. pop the battery out (check it's voltage) and let it sit overnight. Then assemble with the bare essentials and see if it'll post up. Might get lucky, never know.
