Budget (including currency): $2000 give or take a few hundred
Country: USA
Games, programs or workloads that it will be used for: gaming, basic content creation, photo/video editing
Other details: ITX for college
I'm going to college next year and I'm going to be building a new mini itx setup. I will be purchasing these parts in september or so, so let's act like everything is MSRP. Hopefully...
I just sold my old computer, which is in my signature right now. I should get around 2000 from it when all is said and done. I need some advice for a mini itx build in 2021. Obviously this is a high end machine, and I gotta say I'm tempted to do a custom loop. I did a CPU only loop on my last build and quite enjoyed it. With that said, it does seem difficult to plan this for an itx build. I would be using soft tubing and compression fittings so I feel like it would still be fairly portable. As far as the loop goes, I have leftover fittings and tubing so it wouldn't be that expensive.
Anyways, any advice would be appreciated. I want to emphasize quietness on this build while still enjoying a small footprint of a mini itx case.
Basic part list potentially:
5800x
b550
3080 or 3070 (do waterblocks for 3070's exist?)
32GB ram
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/1319651-2000-mini-itx-build/
Just now, Arrogath said:
so best of luck with the GPU hunt. 3070 waterblocks do exist, there are also GPU that you can buy with a preinstalled EK block built by Asus
I already got a 3070 back in november I just sold it because I won't be in the country all summer. I think I can source one hopefully by september.
What do you think about itx cases that would be good for watercooling?
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595699
011 dynamic mini is a pretty interesting new entry... unless you want to build in an extra cramped case
I think that is currently the #1 case I'm considering although it seems kind of large for an itx case. I wish I could see it in person...
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595707
it is quite large for an itx case, you can just look at the specs and use a tapemeasure to get a good feel for the space it takes up. I guess you could look at the TU 150 as well... it just doesn't lend itself as nicely to watercooling
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595711
Are you sure you want to go 3070 or 3080 at this price point?
Even kinda optimising what you've set out there's still not much room for watercooling in term of price from what I could make on pcpartpicker
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595739
I'd recommend more like a 2070 super or 2080 super for $2k. They've also been out for longer so you're more likely to find waterblocks for those cards.
Maybe even look on the used market, body is going to call you some 'pc peasant' for getting a used card for a great price
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595741
I just sold a 3070 with the intention of rebuying it when stock normalizes in september ish when college starts. I won't be buying a non 30 series GPU.
I got a 3070 originally back in november anyways for msrp on newegg. It just took religious refreshing for a week straight but I'm pretty confident I could do it again.
For the sake of a parts list pretend like you can get a 3070 with a waterblock for 700 and a 3080 with a waterblock for 900.
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595747
Ah, that makes more sense now
Maybe go for the 5600x or 3800x instead of a 5800x to save a buck though, they aren't too far off in terms of performance
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595754
I also just sold a 3900x so I won't be downgrading in that respect. I know I want 5000 series but 6 cores is meh
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595795
In terms of case, try to snag a FormD T1 I'd say. 9.5L, great for watercooling and 3-slot GPUs fit too
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595801
I very much like that case... I will look into this.
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14595900
Just wanted to throw out another case recommendation, totally different from the FormD T1 mentioned earlier, the SSUPD Meshilicious, made by a daughter company of lian li. There probably won’t be a way to water cool in this case, the desk footprint is very small, and it comes with mesh just about everywhere, so temps will be decent for an itx case.
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14596579
if you have time and want a custom case, look into Parvum cases, they will also make to the size you want.
for GPU's your going to use a lot of the budget on that because right now so expensive.
you might be able to go for a full on AMD setup for the CPU & GPU. (value for money + performance)
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14597493
I very much like parvum cases I think I'll consider those in my final list.
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14599647
On 3/28/2021 at 1:27 AM, _DeXTeR_ said:
B550 cost around 200$
32GB RAM cost also around 200$
Ryzen 7 5800x cost 480$
3080 cost around 1000$
PC case
Power Supply SSD-s Fans and you already broke your bank limit. Prices are from Newegg
itx b550s can be found as low as 130, plus I can go used market to cut it down further.
32gb ram can be found for 160 ish for 2x16gb 3200mhz cas16, can also go used market to cut it down further
5800x can be found for 450, hopefully less in september. who knows.
I already have a couple nvme ssd's I can use
3080 with waterblock will be around 1000 or 3070 with waterblock for 700
200 for case (maybe less who knows)
75 for fans (maybe less depending on case)
200 for PSU (hopefully these will be cheaper in september)
Then for the custom loop I already have plenty of leftover fittings/tubing so I just need a waterblock and pump/res which I should be able to get used for around 150 total.
All in all I think $2300 with a 3080 and $2000 with a 3070 is reasonable if the used market is in good condition in september.
Good thing I have a full ride for college😅
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14601336
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14601471
On 3/30/2021 at 8:36 AM, _DeXTeR_ said:
If you want to go used thats fine am glad that you can afford what you asked. My thinking was you are going for new PC parts. and also if you can find 3070 or 3080 they are all out of stock.
Parvum cases aren't all that expensive either, and make sure if you want to go with m-itx that you get it an inch taller to fit a 2.7 slot GPU if so desired.
a lot of other pre made manufacture cases don't always have room for a 2.7 slot card so be aware of this when choosing case.
I wouldn't get an i5, the more higher spec the better, i even have a spare i7 8700 laying on my shelf and 16gb of 3200mhz DDR4. maybe you would be interested.
only thing the i7 is 1151 socket.
just go for one M.2 drive even the Gen 3 ones now are cheap enough for a 1TB or 2TB,  i found 256GB too small a drive for windows now,
look into what your motherboard supports and get the spec to suit it.
https://linustechtips.com/topic/1319651-2000-mini-itx-build/#findComment-14610944
