Need help with redoing networking in my house
prayshadow
Hi all, I need some help with redoing my home network, specifically with the hardline part of it.  My house is not currently wired for ethernet, all I have are RJ11 and coax.  I have two coax jacks that are actually active and I currently have a Sparklight internet plan that works with what essentially appears to be two modems.  One is upstairs, one is downstairs, both Hitron units, both connected to coax.  The two modems have different MAC addresses...so I was wondering if it would be possible for me to use one modem upstairs and another downstairs on the same internet plan, or if I'm just going to have to suck it up and run some ethernet cables myself.  I would like to get rid of the equipment I have from Sparklight and install my own, mainly for the fact I can use my own, higher quality equipment, upgrade my internet plant to a faster one and still be saving money on my monthly bill for getting rid of their equipment.  Is there any way for me to be able to use two modems without having to pay for two separate internet plans, or is there another way that I can use coax to share an internet connection from the downstairs to the upstairs?
MoCA
The adapters aren't necessarily cheap, per se, but they do work well (from experience). Make sure you get adapters with pass-through so you can still connect the modem to at least one of the jacks.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | a 10G NIC (pending) | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
No. Usually, for residential internet, it’s one physical line per modem or gateway. Some ISPs might try to get you to rent “extension” devices, but they’re usually just glorified WiFi extenders.
An alternative to MoCA is the obvious: running ethernet between floors. You can run it within the same space that your coax or phone line, provided they can accommodate the girth of the cable’s insulation. If you don’t need the phone line anymore (who does, these days!?) and can find where it starts/ends, you can use that line as a guide wire to fish ethernet through. All you’d have to do is replace the wall plates to include ethernet keystones. The same can be said about the coax cable.
