Hello, I recently bought two ram memory kits (Team Group T-Force Vulcan Z DDR4 3200Mhz PC4-25600 64GB 2x32GB CL16) with the intention of installing 128 gb the maximum supported by my motherboard (MSI Z490-A-PRO) but I could not No way to make it work I can only use a stick of 32 GB at most to get to windows, I tried with all of them individually and they all seem to be working correctly but when I try with more than one it does not matter what combination I try, they all fail to turn on . Among the things that I have tried so far, install the latest bios, lower the frequency a lot, increase the main times, increase the voltages of vddr and vccsa towards 1.5 and 1.4 respectively, clear cmos, and randomly try options that I don't know what they do xd . Is there anything else i can try to make them work? (just in case i have i7 10700k an rtx2070s but i guess it doesn't matter)
https://linustechtips.com/topic/1319246-pc-ram-boot-problem/
3 minutes ago, edgawec12 said:
fuc * I don't know, where can I find it ?
https://www.msi.com/Motherboard/support/Z490-A-PRO#support-mem-31
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
https://linustechtips.com/topic/1319246-pc-ram-boot-problem/#findComment-14592654
Ok my above link may appear blank, but go there, select compatibility on the left side, then press the button called "Memory by 10th gen and other CPU." That worked for me at least.
https://linustechtips.com/topic/1319246-pc-ram-boot-problem/#findComment-14592657
thank you, I forgot that that existed
https://linustechtips.com/topic/1319246-pc-ram-boot-problem/#findComment-14592721
