5 minutes ago, Barshan said:
So the pc model is i3 3rd gen. The cpu cooler is an aftermarket one. ( a korean one). the cooler is not working. When i start the pc right from the time being it dose not works. What could be the problem? Any probable solutions?
is it aio system? ex. inspiron 2748?   i have the sam problem with my fans , they randomly spin , its just that there are sensors in the computer that make that fans spin at a higher rpm for cooling
i5-9400f
corsair 16gb (2x8) kit + 4x1 gb microsoft stick both 2666
asrock b350m pro4 lga 1151
intel ax-210 wifi card
msi rx 580 8gb
nzxt h510 airflow case white
650w thermaltake gold
512gb nvme
1tb wd blue
1tb seagate external
https://linustechtips.com/topic/1318904-cpu-fan/#findComment-14589912
