Previously I got bluescreen, I thought it was caused by my old hard drive. But I found out its the ram causing the bluescreen, the bluescreen code was ATTEMPTED_WRITE_TO_READONLY_MEMORY. The bluescreen happens twice a day, also it happens when I'm recording. So I try to run a ram tester which is Prime95 and I got something. I run the test for 3 hour and heres the result.
I dont know why but I gave the ram enough voltage, I run the ram at 3000Mhz on 1.35v. I use the XMP Profile and crank up the voltage a bit, from 1.25 to 1.35. Also the build is new and fresh. It just turned one year last week.
So can anyone explain whats wrong here, Should I claim the ram warranty?
Ram : Corsair Vengeace LPX 16Gb (8X2) 3200Mhz CL16
https://linustechtips.com/topic/1318727-help-something-is-wrong-with-my-ram/
