Need Help Fixing File Explorer Layout
Go to solution Solved by PCTechBoi,
Click view
Ok so I open file explorer today and it looks like the dark theme image down below. As you can see that is not the normal file explorer layout. The bar is gone on the side. The white theme below is what it is supposed to look like. I did not change any setting yet I get on it and looks different then how it always has. How can I get it back to the defualt layout?
https://linustechtips.com/topic/1318524-need-help-fixing-file-explorer-layout/
