So I have been thinking, my new pc is going to look pretty sweet with all the argb that is getting put in the case. However what I am thinking about is external lights controlled via computer to be the same colour. Thinking either them wall triangle things or led behind the monitors. Is there a way to do this without getting too complicated? I mean I know technically there is but I really can't be bothered with doing a full diy setup including making a circuit that jumps from the motherboard to a controller to usb and so on. So is there something user friendly that plugs all together?
Thanks
https://linustechtips.com/topic/1317893-external-argb/
I would say it depends on the brand of your current airgb strips ands if you want to include them. Corsair makes argb strips and a controller for them that works well and has tons of ports.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1317893-external-argb/#findComment-14581835
well corsair has a kit for monitor lighting its not cheap thow.
or you can diy
for controllers that dont have an removable usb connector and use the 9 pin internal usb you can buy an adapter to make it attach to external usb. 9 pin male to male usb adapter
but you still have to get external power some how.
Edited by thrasher_565
https://linustechtips.com/topic/1317893-external-argb/#findComment-14585419
