Budget (including currency): under 1000
Country: US
Games, programs or workloads that it will be used for: 3D modeling, Anno, civilization, indie and older games
Other details Upgrading from 9 year old laptop. Will be running 27 inch 1080p 60hrs monitor. I would like this to be quiet since it’s going into my bedroom. I want to know if this config will work and if anyone has any suggestions. I’m going to try and use integrated graphics until I can get reasonable gpu.
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  180 @ micro center
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($30.40 @ Amazon)
Motherboard: ASRock Z590 Steel Legend WiFi 6E ATX LGA1200 Motherboard  201 a Newegg
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  80@ microcenter
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  70 @ microcenter
Storage: Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive  ($89.99 @ Newegg)
Case: be quiet! Pure Base 600 ATX Mid Tower Case   80 @ Newegg
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Corsair)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer  ($54.99 @ Amazon)
https://linustechtips.com/topic/1317815-quiet-build/
Country: US
If you want quiet then make it a priority to get a better cpu cooler.
Granted, when a computer is sleeping it's already very quiet and silent if you turn it off at night.
https://linustechtips.com/topic/1317815-quiet-build/#findComment-14581131
You should also invest in a new fan for your CPU cooler, maybe a magnetic case fan like the Corsair ML120 Pro or a good ol' be quiet! Silent Wings fan. It makes a world of difference sound-wise, speaking from personal experience.
"I did it once... I can do it again! That's why I have two children" - Linus 2k15
https://linustechtips.com/topic/1317815-quiet-build/#findComment-14581409
