Static shock power problems.
Solved by frozensun,
Just now, FreakyKai said:Jumped the power switch pins with a screwdriver. Reset CMOS and that was like turning on the power switch at the PSU, computer came on like it was going to boot up but shut down after about 2 sec.
In that case it can be anything,you don't get POST screen because some of the components are deffective.
You will hardly get support here,find a good PC technican and he will know what to do...
I suspect it's RAM,and that would be your best bet.
