Hello,
I have picked some of my parts, but the motherboard part is confusing, just too many options that i do not understand.
I will list all the other parts,
Samsung 120 GB SSD
WD 500 GB HDD
MSI N770 TF 2GB
Corsair 600 Watt PS
Corsair 8 GB (2X4) DDR3 1600 MHz Memory Kit for Core i3, i5, i7 and Platforms SDRAM
Intel Core i3-4130 3.4 3 FCLGA 1150 Processor
BitFenix Computer Case BFC-CLM-300-KKLS1-RP
I think i need a MicroATX motherboard because I'm using a MicroATX tower, but I am not sure which are compatible with my RAM or processor.
Thanks
https://linustechtips.com/topic/131649-help-pick-a-motherboard/
do you have a budget or color of the motherboard preference?
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/131649-help-pick-a-motherboard/#findComment-1751927
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/131649-help-pick-a-motherboard/#findComment-1751974
Thanks for the replies, sorry didn't mention price. Price would be around 90, Do you think this would work? http://www.newegg.com/Product/Product.aspx?Item=N82E16813128616
thanks
That one is fine. The only thing you need to worry about is that the motherboard has the same socket as the CPU. Also that it will fit in the case.
Potatoes are good for your nostrils.
https://linustechtips.com/topic/131649-help-pick-a-motherboard/#findComment-1752020
When picking a power supply, do they follow the same names? as in mATX mITX.....
Because i am looking at the power supply i have, and I'm not sure if it is for the right case or not.
power supply: http://www.amazon.com/gp/product/B004W2T2UQ/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=AZCEI3EMXUPTH
Case: http://www.amazon.com/gp/product/B00HRRJC58/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Do they match?
https://linustechtips.com/topic/131649-help-pick-a-motherboard/#findComment-1752044
Do they match?
Yes, it will be fine too. Usually all power supplies fit all cases, so they do not have to be "same" size.
https://linustechtips.com/topic/131649-help-pick-a-motherboard/#findComment-1752089
