I have a computer and the sd card slot stopped working I bought a converter which converted it to USB and that broke (after a few years.) Does anyone have any reccomentsas about which one to buy it needs to have a long wire as it needs to sit on my desk and I like in the UK?
https://linustechtips.com/topic/1315896-usb-hub/
I bought the North America version of this one in December of 2018. I dunno what there is to say about it. Stuff plugged into it doesn't feel slow. I has yet to break. I haven't used the QC function of it though.
https://www.amazon.co.uk/dp/B07DWQBBZX/ref=redir_mobile_desktop?_encoding=UTF8&aaxitk=kKblxAoQmhaw618T-odAfg&hsa_cr_id=2181974300302&pd_rd_plhdr=t&pd_rd_r=4409d8b9-2d60-4a5b-9222-ff4ead536372&pd_rd_w=CWpqS&pd_rd_wg=1uXkU&ref_=sbx_be_s_sparkle_lsi3d_asin_1_title
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1315896-usb-hub/#findComment-14565861
So you're looking for a SD card reader or USB hub?
https://linustechtips.com/topic/1315896-usb-hub/#findComment-14565865
It doesn't have a sd card slot
https://linustechtips.com/topic/1315896-usb-hub/#findComment-14566095
Buy them separately, have you use the USB header on the motherboard to add more USB ports?'
I suggest getting a USB header instead of using a hub.
https://linustechtips.com/topic/1315896-usb-hub/#findComment-14566098
