24 minutes ago, klerg said:
Pre-Built Systems
It doesn't look like the SFF riser will work. If you look at it, it'll put your GPU upside down and possibly not mount to anything. You might be able to get away with a normal rise and mod it to fit in your case. If you want more PCIE slots than you have, you'll probably have to look into bifurcation. If your motherboard even supports it.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
I was afraid of that hope it can be done. How will my GPU be put upside down and is it the onboard or AGP GPU that will be like this? The riser for Evo D510 SFF is more normal as it fits into a PCI slot and how will case need to be modded? The Evo D510 only has PCI not PCIE slots, what is bifurcation and how to know if the motherboard can do that?
