Its a way to put new firmware on the mouse.
I have the same mouse and it hasn't done it so IDK but I can try
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1315615-mouse-issue/#findComment-14563284
3 minutes ago, PSunknown said:
is there a way to manually update the firmware?
IDK
I don't even know how
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1315615-mouse-issue/#findComment-14563640
this might help
https://forum.corsair.com/v3/showthread.php?t=192708
also you might want to update firmware though icue
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1315615-mouse-issue/#findComment-14563649
corsair has great costumer support so check with them
or I can tag them
@Corsair Nick
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1315615-mouse-issue/#findComment-14563657
On 3/15/2021 at 2:33 PM, PSunknown said:
hi guys
I need help with my corsair m65 pro rgb mouse, every time I plug it in a brings up a window that says CRP DISABLED
Does anyone know what's wrong ?
thanks to anyone who knows anything
You can try performing a soft reset on the mouse by going through the following steps:
  1. Unplug the mouse
  2. Hold the Left and Right Mouse Buttons
  3. While holding the buttons, plug the USB back in
  4. Release the mouse buttons after 5 sec
If this doesn't correct the mouse, you'll need to reach out to support for a hard reset and the files to perform it.  You can submit a ticket through the portal below and one of the agents can provide you with the files and steps:
https://support.corsair.com/
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://linustechtips.com/topic/1315615-mouse-issue/#findComment-14581620
