Budget (including currency):  500-600
Country: uk
Games, programs or workloads  that it will be used for: minecraft with shaders, terraria, assassin's creed ext
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  I need a pc that I can upgrade later on and will play games @1080p with 60 fps on max or high. If this was a pre built it would be much easier.
https://linustechtips.com/topic/1315438-need-help-getting-a-pc/
This is probably what you're looking for: NZXT Starter PC Series (letsbld.com)
With the current market pre-builts are pretty much the only way to get a decent budget PC including a GPU.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1315438-need-help-getting-a-pc/#findComment-14561782
