Fan connector question
Solved by LogicalDrm,
11 hours ago, Gopnik said:I forgot to say the splitter plugs into my PSU and not my motherboard so i cant control the voltage
Did you mix up Antec with Arctic? Idk what you mean by trg, the splitter probably has molex. So yes, they will be at full speed all the time if you connect them directly to PSU. If you connect them to mobo, you can still have voltage controls.
