I need a cable
On 3/14/2021 at 7:44 AM, ToPShaGGeR107 said:I need to find cable for my motherboard
I’m a new builder and just finished my first build but I’m missing a cable for my cpu
I have a ROG Thor 850W Power Supply
and it came with a bunch of cables that fit in my motherboard and power supply but the cpu plug was not fitting in so I bought one and now it won’t fit in my power supply
so I bought an adapter for it and now it fits the cpu cable but not the power supply and then I spent an hour to find a cable that might fit but I can’t find anything that would fit but if anyone would know a CPU - 6+2 PCI-E or anything that would work for a ROG Thor power supply and has a CPU end that would be helpful
I have just bought a new power supply now it works lul and I can’t magically craft me a perfect fitting cable so dumb to think that I’m just putting it in wrong or sumthing
