I rencently upgraded with GPU from a Asus 1080 strix to an EVGA 2080 Super (the one with 2 fans) and I noticed that while gaming my desk lamp is now flickering a lot. It wasn't doing that with the 1080 strix.
Is my PSU now too weak?
Here are my specs:
i7 8086k running at 4.9GHz all cores
NZXT Kraken X52 cooler
EVGA 2080 Super (1815MHz Boost clock)
Asrock Fatal1ty z370 Gaming-ITX/AC
2 sticks of 16GB each G.Skill F4-3200C16-16GVK
1TB 970 EVO m.2
512GB 850 EVO sata
512GB 840 EVO sata
10TB Seagate Ironwolf sata
Corsair SF600 Platinum PSU
Loque Ghost S1 Case
My PC is plugged in a CyberPower UPS (CP1500PFCLCD) + 2 Monitors + Bell 3000 router + a 13 port USB hub, on the battery backup side of the UPS.
The desk lamp and a pair old Logitech speakers (2.1) are plugged in the surge only side of the UPS.
The UPS monitoring software is reporting 468W load when in Ardenweald in World of Warcraft.
Should I replace my SF600 with the SF700 version?
https://linustechtips.com/topic/1314978-desk-lamp-flickers-when-using-pc/
It's not the PSU.
PSUs work like this:  They take AC and convert it to DC.  They only provide as much DC as the load requires and, therefore, only uses as much AC as required.
If the PSU was "too weak" it wouldn't be able to deliver enough DC and shut down.  If the PSU would need so much power that it would cause your lights to dim or flicker, then it would shut down because there wouldn't be enough power to power the system.
What if you were to NOT have the lamp plugged into the UPS?
I know it's only on the surge side, but it's still on the same circuit within the UPS.  Line Interactive UPS are completely passive until they are on battery power.  The only time the two are NOT on the same circuit is when there is no power and you're running on battery.
Another possibility is noise introduced into the line by the graphics card.  Can't say I've tested for this on a 2080, but the EVGA 3090 FTW and the 3090 FE introduce so much noise back into the PSU that it causes some PSUs to shut down, even if the PSU isn't being overloaded.
The lamp flicker especially when I click the optimize button on the adventure table in world of warcraft... What the button does is simulate a bunch adventurer combinations so it's a CPU intensive task. When raiding, the lamp goes crazy especially when fighting against Sir Denathrius.
I entered my system specs on pcpartpicker website and with the strix 1080, the power estimate is 399W.
With the evga 2080s, it's 469W. Remember that my CPU is overclocked.
I checked also on the EVGA website and the recommended power supply for this GPU is 650W.
So I'm going to order the Corsair SF750 and see how it goes.
I'll report back when the new PSU is installed! 🙂
Sounds about right.
No.  The recommendation for the entire system, worse case scenario, is 650W.
On 3/13/2021 at 9:30 PM, KNP54 said:
I plugged the desk lamp directly to the wall instead of the UPS. It still flickers, but it is less noticeable.
A lamp that flickers is one that isn't getting the correct voltage, meaning the voltage drops every time it dims.
A voltage drop large enough to cause a lamp to flicker would only occur at a current well over 10A or about 1.2kW in a 120V system, or 2.4kW in a 240V system, if the wiring is proper. I have a welding transformer that can ever so slightly dim the lights upon switch-on, and that draws about 14A of surge current at 240V, to give you an idea of how much power it takes to dim lights on a proper house wiring system.
Your computer isn't drawing anywhere near that amount, which could mean that there's something horribly wrong with the wiring (very high resistance) causing a significant voltage drop at only a few amps (600W max).
I doubt your new PSU will actually solve the problem, and you need that wiring checked regardless.
2 hours ago, KNP54 said:
16 minutes ago, jonnyGURU said:
So it's halogen?
Did it flicker during your "raid"  last night?
I think the sudden spike in power draw is throwing the circuit supplying that part of the house off a little.
This is assuming the room where OP's PC is located in is sharing the same circuit / breaker with another room, or something.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
And as I've mentioned, if your 600W gaming PC is capable of that, there's something seriously wrong with your wiring.
True, and will also depend on how that part of the house is wired to said 15A circuit breaker, and what is currently connected.
A 15A breaker is rated at about 1800W, for us running on 120V AC.
OP may have a 600W PC, but then his/her sibling in the neighboring room has another 600W PC, plus say a 150W TV.
Total peak would be 1350W.
Assuming OP is not using his PC, sibling is already using 750W, I *could* see the sudden extra 600W load will dim the light for a slip second.
Split second dim, until the transformer or load-line calibration kicks in to compensate the VDROOP.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
Perhaps.
Regardless I'd suggest the OP makes sure the wiring in his house is proper, because a high resistance could indicate some dodgy connection, and dodgy connections are usually what lead to fire.
10 hours ago, jonnyGURU said:
think about it.... those things use a lot of power!  I think the one OP linked is 150W.
150W seems like an awful lot to me for a desk light, even for an inefficient halogen one. I suspect the holder could be rated 150W max but I'd be surprised if anyone has a 150W bulb in there for desk use.
Also at this point I'm curious how the raid went.
It might seem that way to you, but they are real.
NOMA 150W 118mm Quartz Halogen Lamp Canadian Tire
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
1 minute ago, akio123008 said:
I didn't say they don't exist. I said that you don't put one of those on your desk.
Why not? Its not that bad. There is usually a shade on it, not like in those old cop movies where they shine it in your face to get you to answer the question..
Fair enough. I can see how some people may do it, but I think it's quite unusual. Most halogen desk lamps I see online are 50W or less.
2400lm is bright as hell. The reflection on the table would be bad enough to hurt your eyes.
To be fair.. I'm sure that particular one that I linked to would be good for a floor lamp rather than a desk lamp..
