Hi there.
I'm building a new system and I want to run both my CPU and GPU on water cooling.
However, I don't trust myself enough to build a custom loop and it's fairly expensive. This made me decide to buy pre-build systems.
I want a quiet PC, so I thought a Corsair H110 with 140mm fans would be a great choice for the Intel 4770K, but I also want to water cool my GPU.
As I don't want to tinker with the systems, I'm thinking of buying a separate system for this.
My pick now is a combination of a MSI GeForce 770 4Gb Gaming GPU with a NZXT Kraken and a (for budget reasons) Corsair H90.
I could possibly extend the budget for another H110 as the case I picked would fit it, but I like to hear your opinions.
Looking at all this, what would you do without buying a custom loop or combining separate systems into one?
And would the H90 be enough for the GPU or could I better swap the H90 for the H110 and put the H90 on the GPU?
Please let me know. This is my first experience with water cooling on GPU.
https://linustechtips.com/topic/131416-water-cooling-cpu-gpu-seperate-systems/
I'd get something a little better for the GPU. Keep the H110 on the CPU and get something like the H55 or the Kraken X40 from NZXT if you want the 140 mm Rad
The year is 20XX. Everyone plays Fox at TAS levels of perfection. Because of this, the winner of a match depends solely on port priority. The RPS metagame has evolved to ridiculous levels due to it being the only remaining factor to decide matches.
Only Abate, Axe, and Wobbles can save us.
