7 minutes ago, Myles.C said:
well I was hoping to do $1500 - $2000, I mostly was gonna use it for work but also gaming. But not too sure what to get at the moment
What kind of work would you be doing on it? (Photoshop, video editing, 3D rendering, etc)
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550710
Just now, Myles.C said:
well not not a job work nothing really to run the pc like photoshop would. when i say work i say school work. But for gaming I would play cod or pubg
I’d say you would want to go for a ryzen 5 5600 (x version of you want to overclock) or a ryzen 7 from this gen or last gen. If you’re playing in 1080 or 1440 I would go with rtx 2000 series or 3060 ti at most, rx 5000 series will also work and if you’re playing 1080p60 pretty much any gpu that goes for more than 100 dollars (in a normal market) will get you by. If you’re playing 4K, a 2080 or above will get you by, or a current gen Radeon card. As for ram, 16 gigs at least, anything more than 32 will be overkill for gaming. Make sure to get at least an ssd for your OS and other applications that rely on fast storage, and that bigger is better. And your power supply will depend on your final pick for parts, just makes sure it’s 80+ rated and has the capability of about 100 watts more than what your parts will be drawing
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550731
If you have any more questions I’d be happy to help
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550732
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550735
This'd be a build closer to the low-end of your budget:
And a build at the higher end of your budget:
Finally, A build in the mid range (this is the one I'd recommend tbh)
The FUMA 2 isn't required, It'll just provide good thermal headroom. HDD is optional, depends on your storage needs.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550740
In terms of the actual recommendation, I would put a 5800x. 8 cores is going to increase the life of your cpu long enough that you can last bottleneck free until the 50 series from nvidia
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550775
8 cores is going to require a more beefy cooling solution and isn't good value, in terms of the 5800x.
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550778
5 minutes ago, curiousmind34 said:
then get a 3700x
It has lower clocks and a lower IPC. The 5600x gets pretty close to the 3700x even in multi-threaded workloads, in gaming workloads which OP is primarily concerned about, It's no contest. "Bottlenecking" Is also subjective. In most games you're going to get higher frame rates with a 5950x than a 5900x for the RTX 3080. Technically, that means the GPU is bottlenecked. Would you consider a 5900x a bottleneck for the 3080?
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550784
Ayo I was wondering knocking two birds with one stone in my case is this a good pc build in your opinion I know its incomplete but I just need your opinion on it
PCPartPicker Part List: https://pcpartpicker.com/list/PZ9hJf
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($300.00)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler  ($111.99 @ Amazon)
Motherboard: Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard  ($220.00)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($93.99 @ Newegg)
Video Card: Asus GeForce RTX 3080 10 GB TUF GAMING Video Card  ($700.00)
Case: Phanteks Eclipse P500A D-RGB ATX Mid Tower Case  ($130.00)
Total: $1649.97
Generated by PCPartPicker 2021-03-10 22:40 EST-0500
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550819
2 hours ago, Jayzer said:
What do you think about this
[PCPartPicker Part List](https://pcpartpicker.com/list/PZ9hJf)
Type|Item|Price
**CPU** | [AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor](https://pcpartpicker.com/product/g94BD3/amd-ryzen-5-5600x-37-ghz-6-core-processor-100-100000065box) | $300.00
**CPU Cooler** | [ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler](https://pcpartpicker.com/product/smDkcf/arctic-liquid-freezer-ii-280-728-cfm-liquid-cpu-cooler-acfre00066a) | $111.99 @ Amazon
**Motherboard** | [Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard](https://pcpartpicker.com/product/6jFKHx/asus-tuf-gaming-x570-pro-wi-fi-atx-am4-motherboard-tuf-gaming-x570-pro-wi-fi) | $220.00
**Memory** | [Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory](https://pcpartpicker.com/product/2TFKHx/crucial-ballistix-16-gb-2-x-8-gb-ddr4-3600-memory-bl2k8g36c16u4b) | $93.99 @ Newegg
**Video Card** | [Asus GeForce RTX 3080 10 GB TUF GAMING Video Card](https://pcpartpicker.com/product/DgMTwP/asus-geforce-rtx-3080-10-gb-tuf-gaming-video-card-tuf-rtx3080-10g-gaming) | $700.00
**Case** | [Phanteks Eclipse P500A D-RGB ATX Mid Tower Case](https://pcpartpicker.com/product/LVQfrH/phanteks-eclipse-p500a-d-rgb-atx-mid-tower-case-ph-ec500atg_dbk01) | $130.00
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$1649.97**
 | Generated by [PCPartPicker](https://pcpartpicker.com) 2021-03-10 23:35 EST-0500 |
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550880
Type|Item|Price
Budget? What will you use it for (e.g AAA gaming, video editing, etc.)? Need any peripherals?
→  Kindly quote or mention me if you would like a reply back.
<famous quote>
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550883
For the mouse, I didn't include one. You need to go to https://www.rocketjumpninja.com/ and select all the options that match your hand, like how you use it (claw, palm), if you want the mouse to be symmetrical on the other side, and you also need to input your hand length (measure from your wrist) and your hand width.
After that, it'll give you several options on which mouse suits your 'needs', pick one, and then you can add that to the list.
<famous quote>
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550896
11 minutes ago, Zvny said:
Oh just a little change I was wondering maybe if you could recommend a pcie gen 4 nvme ssd for me if it wouldnt bother you
You can get a Corsair Force Series MP600 1TB.
<famous quote>
https://linustechtips.com/topic/1314112-first-build-need-help/#findComment-14550980
