What is a good/safe application that I can use to run my computer on my laptop from a different location? I don't know what you would call that, if anything. Thank You.
Current Pc Parts:
-CPU: Intel i7-9700k
-GPU: EVGA RTX 2070 black edition
-CPU Cooler: NZXT Kraken x62
-Mobo: Asus z390-E gaming
-Ram: Corsair Vengeance RGB pro 32g @3000MHz
-Storage: Samsung 850evo 256Gb
-Storage: Toshiba 1Tb 7200rpm
-Case: NZXT H500
-Extra: NZXT Hue 2
Teamviewer, install and run at both pc.
you can also try Parsec (its what LTT uses for their work from home) or Rainway
