9 minutes ago, anonymousElefant said:
go gold
80+ gold isn't a requirement.
@Nicolas192both of these units have quite a lot more power than you need. what country are you buying in? Are you planning on upgrading to really demanding hardware some time in the near future?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1312651-help-me/#findComment-14538766
Hello! I am from Argentina and I planning to buy a rtx 2060.
https://linustechtips.com/topic/1312651-help-me/#findComment-14538801
You could get a 500 or 550 watt power supply and still have lots of watts left over.
How much do those units cost? compare to something like these
https://ar.pcpartpicker.com/product/FdRFf7/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020121-na
https://ar.pcpartpicker.com/product/zphmP6/antec-neoeco-gold-zen-500-w-80-gold-certified-atx-power-supply-ne500g-zen
Primary PC:
PSU tier list
https://linustechtips.com/topic/1312651-help-me/#findComment-14538827
16 minutes ago, Fasauceome said:
Hello, I have been looking and unfortunately those 2 sources that you recommended are something "difficult" to get here, the corsair arrives in a few units and almost never have stock. And the other one doesn't even go into the country.
Similarly, I had already searched and what I would like to acquire would be one of those two mentioned above. From the be quiet I have an idea of the product, but the asus I find almost no information and that is why I came to this site to know if it is better than the other. The price difference here is minimal between one model and another so the economic doesn't matter.
https://linustechtips.com/topic/1312651-help-me/#findComment-14538888
The be quiet unit is a good unit so I will recommend that one. Asus power supplies are all a different design with the Asus logo on it, I don't know which design the one you mentioned is but chances are the price was increased just for the branding.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1312651-help-me/#findComment-14539021
