11 hours ago, Luckyy said:
yeah i'm selecting the ssd in boot menu but it just goes blank then goes to windows on my main ssd
I am guessing it is a conflict between the windows boot manager and grub.
You should try reinstalling your Linux distro
Try a distro with the ubiquity installer
 It gives in built options to dual boot.
https://linustechtips.com/topic/1311505-help/#findComment-14530473
