2 minutes ago, Tareku said:
Hey guys, got a new mobo B550m Steel Legends and I am getting no audio from the front or back jacks at all.
I have tried everything I could think of.
is there something I am missing other than an RMA ?
make sure front audio cable is plugged in ALL THE WAY.
Also install drivers.
What is the rest of your system?
The audio ports on the back of the mobo are typically better, so try to use those.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
I stopped caring about the front ones a while ago because that could be from user error. I will say that I have built many PCs so I would hope "push it all the way in" (lol) isn't my issue. But the back ones do not work either. Updated bios to latest, chipset, audio drivers. Everything is up to date.
Here are the specs:
Ryzen 7 3800XT
B550M Steel Series
32GB (4x 8GB) Trident Z
Zotac RTX 3070
850W PSU Gold Evga
Bunch of HDD lol
Your audio dac is most likely dead. RMA it.
1 minute ago, Tareku said:
fuck lol
edit:
would that make the front panel jacks not work as well ?
You would lose all analog input and output. If you have optical output, that in theory still should work.
