Problems with my RTX 3070. Constant crashing and instability.
Solved by Kilrah,
You've now got both a PCIe Gen4 capable mobo and GPU, so they'll try to run at that speed but the riser likely degrades the signal too much, there aren't really many that are properly rated for 4.0 at the moment.
So go in the BIOS and manually limit the slot to PCIe Gen3.
Featured Topics
halfbood_drag0n ·
3
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
