Help with CSS Responsive layout
Solved by popeldd,
Since I do not know your html, I could tell you that your css looks extremely specific in terms of displays, positioning, and height/width.
I havent done CSS in a little bit. But no worries, I've got a useless certification in it lol.
I find it fun learning hands on, so I would highly recommend you play around with the following:
- Make sure you know your CSS Grid Layout
- Understand the different display values
- Understand the different position values (Absolute positioning is absolute, meaning it will stay where it is defined. Relative is relative to other items around it, depending on the display values (there are other positions, but these are the starting two))
- you can use percentages(%) instead of pixels(px) for height/width (not always useful, but it may come in handy)
- after knowing the css grid layout, try changing display to flex (but if you are confused in any way about other things I've said, just forget this bullet point, you'll eventually come across it)
I may be a bit confusing, but w3schools and other documentation sites are really helpful.
