Hello everyone im going to be getting Corsairs 760T case when released (04/15/2014).
I want to know what kind of fans you would inside the case...(not just front, not just back or bottom, fans for the entire case..
Also i will be mounting Swiftechs H220 rad on the top of the case..
https://linustechtips.com/topic/130961-case-fans-help/
Gentle Typhoons or SP/AF
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/130961-case-fans-help/#findComment-1742955
sp/af??
Corsair SP120/AF120
SP120
AF120
https://linustechtips.com/topic/130961-case-fans-help/#findComment-1742987
I'd stick with an "All Corsair" case. Meaning AF / SP fans, PSU, ssd, ram, AIO and maybe even corsair link for the fan controller.
While you're at it why not get a corsair peripheral set?  :))
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/130961-case-fans-help/#findComment-1743022
All ready have my build setup just waiting on case... only corsair products in my build is the psu and case
https://linustechtips.com/topic/130961-case-fans-help/#findComment-1743111
Bequiet makes good fans for case ventilation, but scythe GTs aren't bad eitehr. latter ones are sposedly good on rads. The corsair fans are good performers and look nice, if you can handle the noise. I am a silence freak, and i find them terrible, but that's just me. :D
who cares...
https://linustechtips.com/topic/130961-case-fans-help/#findComment-1744482
NoiseBlocker BlackSilent Pro
This or the GTs
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/130961-case-fans-help/#findComment-1749602
