PC not starting properly
Go to solution Solved by SEAL62,
1 minute ago, BunnyHunter67 said:
When windows did the disk recovery, I had an option to keep my files but reinstall windows. Would this option be enough? or should I do a full clean install.
Sounds good doesn't work 😄
Better copy your files to a seperate drive, do a clean reinstall and than copy your data back.
When I try to start my pc, it loads forever on the post screen. Once I force shut down the computer and relaunch, it goes through automatic disk repair and launches normally. My computer has changed a lot recently, making it hard to pinpoint what is causing it. I recently swapped out my GPU from a 1070 to a 3080, and one of my ram sticks died so I replaced it. The problem started some time after these changes happened.
https://linustechtips.com/topic/1309410-pc-not-starting-properly/
What drive do you use for your OS?
Do you have any spare RAM that you could check (a pair), just in case your other RAM stick is faulty now or the new and the old one don't match together?
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
My boot drive is a 1TB sata ssd. And I don't have any spare ram to check. But I do have memtest from when I was figuring out what was wrong with my ram. I haven't ran memtest on the new ram stick yet.
You could check your boot SSD for failure, maybe that causes the issue, but I would say it is just a bad windows install, so maybe think about reinstalling your OS.
Does your mobo have a speaker or some indicator LEDs that might show what hardware component might be the problem?
OS: Windows 10 Pro
OS: Kali Linux
It's an asus board and the two digit error code just says A0. Which after looking it up, seems to be a normal code.
Yes that is normal, so I would say that your hardware is probably fine. Seems to be a faulty Windows install
-> reinstall WIndows and everything should work just fine again
OS: Windows 10 Pro
OS: Kali Linux
OS: Windows 10 Pro
OS: Kali Linux
The problem is that you will have a hard time copying all your games or other installed programs since your windows install is bad. So better just copy your data and the folders that have your saved games in them and reinstall your software after your fresh windows install.
You could use something like acronis true image for that, which can be found with let's just say a very heavy discount 😄 on certain sites.
OS: Windows 10 Pro
OS: Kali Linux
