I was looking through the specifications of my motherboard since my Rosewill CAT 6 cable wouldn't fit and I couldn't find if they were compatible (https://www.newegg.com/p/N82E16812119161?Item=N82E16812119161
Motherboard LAN port: 1x Intel® I219-V
(https://www.msi.com/Motherboard/Z390-A-PRO/Specification)
https://linustechtips.com/topic/1308613-lan-port-question/
If there is a shield on the end of the cable, cut it off, if that doesn’t work, then check your port for anything, but any RJ45 cable should work.
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1308613-lan-port-question/#findComment-14505572
Just now, Luckyprock said:
It seems to fit but it doesn't click in and it slips out without any force so I'm not totally sure where I went wrong
Is the tab in the cable still there? Those can snap off quite easily.
Try wiggling it around in the port a bit.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/1308613-lan-port-question/#findComment-14505584
If your talking about the little plastic tab to release it, yes, however it doesn't engage in this port
https://linustechtips.com/topic/1308613-lan-port-question/#findComment-14505594
Ah, the boot might be causing an issue. Try to really push the cable in there until you hear a click or cut off the boot around the clip if you want to be extra sure.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1308613-lan-port-question/#findComment-14505708
I cut the boot and tried putting it in as far as I could and theres still nothing
https://linustechtips.com/topic/1308613-lan-port-question/#findComment-14505842
That's really weird, it should just click right in.
Prior Build Log/PC:
https://linustechtips.com/topic/1308613-lan-port-question/#findComment-14506104
